7Days to die Starting Loop
OS Name/Version:AMP Release “Halimede” v2.4.0.8, built 10/10/2022 21:18
Product Name/Version: 7Days to Die Alpha 20.6 (b9) Compatibility Version: Alpha 20.6, Build: LinuxPlayer 64 Bit
Mod: Apocalypse Now Mod V3.0.6 Stable
Problem Description: When adding mods to server, server always displays “Starting 7 days to die”
Also after the last update this instance removes world settings and saved maps. this has happened over the past 2 updates.
with vanilla world this is not an issue, is there a setting I have to adjust to work with mods?
Thanks in advanced
Hey @Ohraz,
I saw your post and wanted to help troubleshoot your 7 Days to Die server startup loop when using mods. Since the vanilla world works fine, but the issue happens with Apocalypse Now Mod V3.0.6 Stable, here are a few things to check:
Steps to Try:
  1. Verify Mod Compatibility – Make sure Apocalypse Now Mod V3.0.6 Stable is fully compatible with 7 Days to Die Alpha 20.6 (b9).
  2. Check for Missing Libraries – The logs show repeated fallback handler errors related to missing libadvapi32.dll. Try manually installing the missing libraries or verifying the integrity of the game files.
  3. Test Without Mods – Run the server without mods to confirm that it starts properly. If it works fine, the issue is likely mod-related rather than an AMP or game server issue.
  4. Adjust Mod Load Order – Some mods may conflict with each other. Try loading Apocalypse Now Mod first and then adding other mods one by one.
  5. Check AMP Configuration – If AMP is resetting world settings and saved maps, check if there’s an auto-reset setting enabled.
  6. Upgrade AMP – Since this issue was reported in 2022, upgrading to the latest AMP version might resolve compatibility issues.
Let me know if any of these steps help or if the issue persists—I’d be happy to troubleshoot further!
