OS Name/Version: Ubuntu server 24.04.2 LTS (running on proxmox)
Product Name/Version: AMP 2.6.2
Problem Description: For some reason, backups for 7 days to die don’t work. When I hit the create backup button, it says it’s building file system, but then it just stops and no backup is created. Notably, I’ve tried to designate a datastore on a partition on a different drive as the location for backups, but this problem existed before I set that up, and I also have a Minecraft server instance that I set up to backup to the storage and it works fine. The instance console doesn’t provide any information (because the instance is shut down when I try to create backups) and the deployment log simply acknowledges that I managed a remote instance. What additional information might be helpful for troubleshooting the backup issue?
Step 1: Deploy a 7 Days to Die instance and launch
Step 2: Set up a datastore on a separate HDD partition for storing backups by following the steps in the " How to change backup locations" documentation.
Step 3: Attempt to create a backup and see it terminate without creating the backup.
Actions taken to resolve so far: Tested the “change backup location” process on a different instance running Minecraft to see if there was an issue with the process. Checked the syntax of my configuration files multiple times.
