**Note: If you do not fill in all the fields, your contribution will not be answered. You must indicate the steps you have taken so far and the actions you have already taken. Make sure to remove this note from your post as well **.
Operating system name/version: debian-11.6.0-amd64
Product name/version: AMP Instance Manager v2.4.6.2
When calling https://amp.pg92.net/ I get a 502 bad gateway (openresty). I can rule out the reverse proxy configuration to that extent.
The problem seems to be within the Nginx web server configuration in AMP or within the AMP Config, see AMPConfig.conf.
Actions taken so far to resolve the issue:
Troubleshooting. This is not a firewall issue.
Nginx Configuration:
#AMP Configuration File
#DO NOT EDIT WHILE AMP IS RUNNING
Security
Security.ExecPath=Exec
Security.AllowConcurrentSessions=True
Security.LogAuthFailures=False
Security.AuthFailureLogPath=./AuthFailures.log
Security.LogSensitiveProcArgs=False
Security.EncIV=w/w/DduHkEKwEnjvqobv/g==
Security.EnablePassthruAuth=True
Security.PassthruAuthLocalOnly - Only allows auth requests that come from 127.0.0.1 - careful when using a controller that is bound to a specific IP rather than 0.0.0.0!
Security.PassthruAuthLocalOnly=False
Security.AuthFailureTimeWindow=5
Security.AuthFailureAttemptsInWindow=5
Security.TwoFactorMode=Required
Security.RequireSessionIPStickiness=True
Security.AllowAPIDiscoveryWithoutLogin=False
Webserver
Webserver.Port - NEVER CHANGE THIS SETTING MANUALLY! Always use ampinstmgr rebind to alter IP/Port bindings. IF YOU CHANGE THIS ON ADS YOU WILL BREAK YOUR LOGINS!
Webserver.Port=8080
Webserver.IPBinding - NEVER CHANGE THIS SETTING MANUALLY! Always use ampinstmgr rebind to alter IP/Port bindings. IF YOU CHANGE THIS ON ADS YOU WILL BREAK YOUR LOGINS!
Webserver.IPBinding=0.0.0.0
Webserver.SessionTimeout=5
Webserver.NoUI=False
Webserver.FilterEndpoints=False
Webserver.AllowedEndpointIPs=[“127.0.0.1”]
Webserver.CertificatePath=
Webserver.CertificateSerial=
Webserver.CertificateDomain=
Webserver.CertificatePassword=
Webserver.EnableWebSockets=True
Webserver.EnablePluginWSStreams=False
Webserver.EnableFetchPostEndpoints=True
Webserver.APIRateLimit=1000
Webserver.AllowGETForAPIEndpoints=False
Webserver.UsingReverseProxy=True
Webserver.ReverseProxyHost=172.19.11.2
Webserver.CORSOrigin=
Webserver.DisableCompression=False
Login
Login.UseAuthServer=False
Login.AuthServerURL - The URL for the ADS instance providing authentication when using UseAuthServer
Login.AuthServerURL=https://amp.pg92.net/
Login.MetricsServerPort=12820
Login.UseLDAPLogins=False
Login.LDAPAuthDomain=
Login.LDAPGroupPrefix=AMP_
Branding
Branding.DisplayBranding=False
Branding.PageTitle=Provider Page Title Not Set
Branding.CompanyName=
Branding.WelcomeMessage=
Branding.BrandingMessage=
Branding.ShortBrandingMessage=PoweredByAMP
Branding.URL=
Branding.SupportURL=
Branding.SupportText=
Branding.SubmitTicketURL=
Branding.LogoURL=
Branding.BackgroundURL=
Branding.SplashFrameURL=
Branding.ForgotPasswordURL=
AMP
AMP.InstanceID=2d4d409f-5b84-4548-99b8-aa6474e23b34
AMP.InstanceName=ADS01
AMP.FriendlyName=ADS
AMP.AppModule=ADSModule
AMP.LoadPlugins=[“FileManagerPlugin”,“EmailSenderPlugin”,“WebRequestPlugin”,“LocalFileBackupPlugin”,“CommonCorePlugin”]
AMP.ScheduleOffsetSeconds=0
AMP.AppStartupMode=StartApplication
AMP.FirstStart=True
AMP.ShutdownProperly=True
AMP.Suspended=False
AMP.SuspendReason=
AMP.RequireActivation=False
AMP.PreviousVersion=
AMP.DatastoreConnectionString=./datastore.dat
AMP.MapAllPluginStores=True
AMP.IgnoreCTRLC=False
AMP.Theme=Black
AMP.PrimaryEndpoint=0.0.0.0:2223
AMP.PrimaryEndpointUri=sftp://0.0.0.0:2223
AMP.DisplayBaseURI=
Monitoring
Monitoring.UseMulticoreCPUCalc=True
Monitoring.IgnoreSMTCores=True
Monitoring.ConsoleScrollback=10
Monitoring.TitleSuffix - Suffix to append to the terminal title
Monitoring.TitleSuffix=
Monitoring.KeepProvisionConfigs=False
Monitoring.LogLevel=5
Monitoring.EnableConsoleColoring=True
Monitoring.LogsDirectory=AMPLogs
Monitoring.ProduceStartupScripts=False
Monitoring.DeleteOldLogs=True
Monitoring.LogRetentionDays=28
Monitoring.AuditLogRetentionDays=14
Monitoring.FullMetricsGathering=False
Monitoring.ReportPhysicalMemoryAsTotal=False
Monitoring.MetricsPollInterval=1000
Monitoring.ServerLocale=en
Privacy
Privacy.PrivacySettingsSet=False
Privacy.AutoReportFatalExceptions=True
Privacy.AllowAnalytics=False
Limits
Limits.NumericValueNodeUpperLimits={}
Limits.NumericValueNodeLowerLimits={}
