OS Name/Version: Windows Server 2022
v2.4.1.2, built 21/12/2022 17:54
Unable to add a new Valheim Plus instance as the template is not in the default list.
- Create New Instance from AMP
- Attempt to select Valheim Plus
- Entry is not in the list
Actions taken to resolve so far: Tried a reboot and re-download of the list from the master repo CubeCoders/AMPTemplates
Mike
2
There is no separate ValheimPlus entry any more. Valheim Plus is now an option within the standard Valheim configuration.
Hey Mike,
Thanks for the reply, sorry to waste your time with this, just found this post: Merged Valheim and Valheim Plus templates. (#241) · CubeCoders/AMPTemplates@34b47c8 · GitHub
I’m all sorted.
Cheers,
BFG
system
Closed
4
