Valheim+ Instance not applying configurations to Server
OS Name/Version: Win10
Product Name/Version: 2.4.1.2
I am going into the configuration settings for Valheim+ within the AMP Manager instance. I am able to turn settings on and off and the manager is showing them as saved. However when then playing on the server itself the configurations have not been applied to players.
  • Step 1: Make server
  • Step 2: Make changes in configurations
  • Step 3: Start server and play
I have rebooted the server within the instance. I have also shut down the instance itself and rebooted that. I have updated the instance after each of these attempts just in case.
I am having the same issue.
Server works but Valheim Plus settings do not seem to be with the new way.
Had old instances that worked just fine before the change made to instance creation.
Also having the same issue.
Even though I have enabled ā€œValheim Plus Enableā€ in the Server settings it still isn’t working.
