I get “steamcmd needs to be online” error when attempting to run PZ server. This is after initial setup. Instance manager has been updated.
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
[ 0%] Checking for available update...
[ 0%] Downloading Update...
[----] !!! Fatal Error: Steamcmd needs to be online to update. Please confirm your network connection and try again.
threadtools.cpp (3294) : Assertion Failed: Illegal termination of worker thread 'Thread(0x0x629c7380/0x0xea8c0b'
It has not, unfortunately. I have verified network access from the host and the container itself with, google.com resolves and responds from both ipv6 and ipv4, curl and ping.
If it returns an unexpected internal or unrelated IP address, check your DHCP DNS search domain and any wildcard DNS records. Removing that incorrect fallback fixed the issue for me.
As a test before you do any of it, you might just install a totally new instance to see if it duplicates the same problem and that there wasn’t some type of install issue.
I do have my expected server in /etc/resolv.conf, which seemed to have been root cause at the link you shared, and it is returning records as I would expect.
Very much scratching my head here. I did find another game server that uses steamcmd, black mesa, and it fails with the same issue. I assume forums aren’t blowing up with duplicates of this issue, so I do feel that it’s an issue with my configuration…
Popped open the stderr.txt:
cat /home/amp/Steam/logs/stderr.txt
crash_20260905035526_5.dmp[101]: Uploading dump (out-of-process)
/tmp/dumps/crash_20260905035526_5.dmp
Assert( Assertion Failed: Illegal termination of worker thread 'Thread(0x0x61e2f380/0x0xf58aeb' ):threadtools.cpp:3294
crash_20260905035526_5.dmp[101]: Finished uploading minidump (out-of-process): success = no
crash_20260905035526_5.dmp[101]: error: Could not resolve hostname
crash_20260905035526_5.dmp[101]: file ''/tmp/dumps/crash_20260905035526_5.dmp'', upload no: ''Could not resolve hostname''
Upload of a crash fails to something not resolving but that doesn’t explain a crash?
/tmp/dumps has a crash but it’s a really ugly trace, only the first few frames are steamcmd.
This one sounds really dumb, but check it anyway…make sure your clock and date are set/synced correctly. Steamcmd doesn’t play nice if they aren’t.
This is a vanilla PZ server, without mods, right? Double checking that.
Assuming that is ok, can you run steamcmd and install a server from bare metal (ie not in docker?). Might test that. If no, check the firewall settings on the server machine. If yes, at least we know it is a container problem.
Follow up edit…I just found an old posting that said this:
I added those values to /etc/hosts, still no dice. I opened another log, and this is what I’ve found:
[2026-09-06 02:46:18] Startup - updater built Dec 13 2017 05:27:43 [2026-09-06 02:46:18] Checking for update on startup [2026-09-06 02:46:18] Checking for available update... [2026-09-06 02:46:19] Download failed: http error 0 (``client-download.steampowered.com/client/steam_cmd_linux``) [2026-09-06 02:46:19] Download failed: http error 0 (``media.steampowered.com/client/steam_cmd_linux``) [2026-09-06 02:46:19] failed to load manifest from buffer. [2026-09-06 02:46:19] Failed to load manifest [2026-09-06 02:46:19] Error: Download failed: http error 0 [2026-09-06 02:46:19] Verifying installation... [2026-09-06 02:46:19] Performing checksum verification of executable files [2026-09-06 02:46:19] Unable to read and verify install manifest /AMP/project-zomboid/package/steam_cmd_linux.installed [2026-09-06 02:46:19] Verification complete [2026-09-06 02:46:19] Downloading Update... [2026-09-06 02:46:19] Checking for available update... [2026-09-06 02:46:19] Download failed: http error 0 (``client-download.steampowered.com/client/steam_cmd_linux``) [2026-09-06 02:46:19] Download failed: http error 0 (``media.steampowered.com/client/steam_cmd_linux``) [2026-09-06 02:46:19] failed to load manifest from buffer. [2026-09-06 02:46:19] Failed to load manifest [2026-09-06 02:46:19] Error: Download failed: http error 0 [2026-09-06 02:46:19] Error: Steamcmd needs to be online to update. Please confirm your network connection and try again. [2026-09-06 02:46:19] Shutdown
I am able to wgetmedia.steampowered.com/client/steam_cmd_linux from within the pz container and get the binary, but the whatever script that runs on creation is failing.
It was an issue with the version of docker! I ran the command by hand, and found a new error entry;
root@amp:/AMP# ./project-zomboid/steamcmd.sh
Redirecting stderr to '/root/Steam/logs/stderr.txt'
CreateBoundSocket: failed to create socket, error [no name available] (38)
threadtools.cpp (3294) : Assertion Failed: Illegal termination of worker thread 'Thread(0x0x58252380/0x0xf1cb2b'
The socket issue is a very specific footprint from the specific version of docker I was using, 29.4.2. Updated and it was immediately fixed. Glad it was slightly more than a configuration issue.
