Update Failure with Palworld - Palworld instance not updating
Application Palworld
Palworld instance is not updating to the latest patch. I stop the instance and run the update but it does not update. I create a new instance and it is the latest version but am unable to just spin it up as the replacement due to not being adept enough. any support would be appreciated
  • ran updater
  • made new instance
  • updated amp on server
After you enter the instance and hit the Update button, click on Console. There should be a string of text rolling by as it tries to update. See if you can determine the error from that or paste it here.
