Update Failure with Enshrouded - Issue with updating and maintaining instance
Application Enshrouded
Enshrouded instance always fails to update on the schedule that I have set for it. Now it wont let me start the instance up since 1.0 came out. I’m wondering if I should just back up what is here and set up a new instance with the old save data. Any advice would be helpful! Thank you!
  • Automatic updates wont work, wont connect to Steam even after I’ve reconnected it and gotten it to update a few times
  • After Enshrouded went into 1.0, I haven’t been able to launch the instance
  • Updates and backups always fail even after setting old backups to delete after a while
Not an expert here on this but have you tried doing a template update first before the instance update?
Basically, at the screen where it shows all your instances, hit the update button there, then go into the enshrouded instance and hit update again there to see if that fixes it.
