OS Name/Version: Windows 10 os 19044.1526
Product Name/Version: (Always use the full version number - not ‘Latest’) 2.3.2.0
Problem Description: When I try to start my default instance through AMP Instance Manager it doesn’t start. The browser popup thing appears but then it just says something about not being able to connect to the site. I had previously amp installed on my pc but installed it when I stopped using it because I started running my mc server through java. I now want to go back to it but it doesn’t work.
provides syntax highlighting.
- Step 1 Delete then download amp version 2.3.2.0.
- Step 2 At the end of the setup the browser popup will appear.
- Step 3 It doesn’t load in for me.
I’ve tried using some advice on the discord server but it didn’t work. I tried using ampinstmgr startall, I’ve used ampinstmgr startup, and I’ve tried reinstalling amp.
