| Product | AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | Docker |
| Application | Terraria |
| Module | GenericModule |
| Current State | Starting |
Terraria Server seems to be permanently stuck on the “starting”; I can log into the server and play as normal, and everything seems to be working 100%, but the AMP manager doesn’t seem to realize it; Main problem is that I can only close it by “aborting” instead of properly closing as should be.
I have had the Hostinger AI assistant restart the AMP manager, I have restarted the whole VPS server, neither seems to work, whenever Terraria server is started, AMP thinks its stuck on “Starting Terraria”.
(For further context, as of the time of posting the ticket, the server has been in the “starting” state for over 8 hours now; Can use it as normal though)
- Create Terraria Instance
- Start Server (log in Steam as needed)
- Problem happens, despite server being online and it being possible to log into it.
