Startup Issue with Seven Days To Die - Application fails to start
Operating System Linux - Ubuntu 26.04 on x86_64
Application Seven Days To Die
7 days to Die application fails to start with exit code 0 and I do not know what could be causing this issue now
  • Restarted both the instance and the pc running it
  • Check disk space on pc to make sure amp had enough space
  • updated the instance and AMP software
Might post the logs to see if there is more information. You sure you have enough memory if this is a VPS?
