| Product | AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | Podman |
| Application | Project Zomboid |
| Module | GenericModule |
| Current State | Starting |
New Project Zomboid instances seem to hang on the “Starting Project Zomboid” process. Reinstalling, restarting, etc. have not helped the issue.
- Install new Project Zomboid instance
- Left it running to start
- Uninstalled and removed the instance
- Restarted the system
- Second attempt at installing new Project Zomboid instance
Update (solved):
The server status was hanging because no admin password was set by default. This caused an error and prompted the user to set one. AMP should probably include a default password on setup.
LOG : General f:0 st:192,961,299> version=42.20.0 a2947723ca demo=false
LOG : General f:0 st:192,961,300> revision=a2947723ca
LOG : General f:0 st:192,961,303> map_t.bin does not exist, cannot determine the server's WorldVersion. This is ok the first time a server is started.
LOG : General f:0 st:192,961,304> Loading networking libraries...
LOG : General f:0 st:192,961,304> Loading steam_api...
LOG : General f:0 st:192,961,304> Loading RakNet64...
LOG : General f:0 st:192,961,305> Loading ZNetJNI64...
LOG : General f:0 st:192,961,307> SteamUtils initialised successfully
[S_API] SteamAPI_Init(): Loaded local 'steamclient.so' OK.
Setting breakpad minidump AppID = 108600
SteamInternal_SetMinidumpSteamID: Caching Steam ID: 76561197960265728 [API loaded no]
LOG : General f:0 st:192,961,995> Waiting for response from Steam servers
LOG : General f:0 st:192,962,736> compressionElapsed=25ms, mergingElapsed=13ms
LOG : General f:0 st:192,962,737> Backup made in 40 ms
LOG : General f:0 st:192,962,808> User 'admin' not found, creating it
LOG : General f:0 st:192,962,808> Command line admin password: null
LOG : General f:0 st:192,962,808> Enter new administrator password:
