Just replying to my own issue. So I had multiple issues at once. At first I got a 0x2 error. Then I got a “The application stopped unexpectedly. Exit code 3”. Afterwards I got a “ERROR! Failed to install app ‘2394010’ (Missing configuration)”. And finally, “Error! App ‘2394010’ state is 0x6 after update job.”
I am just going to list what I did to fix things one by one as I moved forward to fixing my overall issue.
AMP didn’t actually update. I had to use the update instructions to get that going. That was my initial issue with 0x2. It sounds like 0x2 generally seems to be a storage/space issue. I needed more space in the drive to be able to update AMP. Once I got more space, I followed the update instructions.
I also turned off “Enable Multi-Threaded Performance Improvements”. Removed the toggle for this.
Lastly, I messed with UE4SS as mentioned in this video. I believe this issue is fixed by CubeCoders developers but i didn’t realize this until afterwards and still followed it. https://youtu.be/HAjtCKYAN-o
“The application stopped unexpectedly. Exit code 3” - I tried to start the server again after the above and I am not sure what fully fixed this issue but I saw a few posts in the discord that this was due to c++ redistributables.
I downloaded c++ redistributable x86 and x64. Restarted afterwards. I ran the update afterwards on the instance, it did fail.
I also saw another post that mentioned that this is due to save corruption which I found stated in the following path for CrashContext.runtime-xml or . I had a saved backup from 9 months ago that I restored to and restored through the AMP Backup page. Your file path to the may different from my tatertot path since that is the server instance I made. C:/AMPDatastore/Instances/TaterTotsCattyHole/palworld/2394010/Pal/Saved/Crashes/UECC-Windows-4F525CDA4249F497B65D40A3AFDFB07A_0000/CrashContext.runtime-xml
After running through #2, the next error was “ERROR! Failed to install app ‘2394010’ (Missing configuration)”.
This one I tacked by deleting the steamapps folder. Your path may differ from mine.
Step #3 did fully help me but it did lead me to a new error which was 0x6 which now led me to find out that the appmanifest files can be corrupted. I found mine in the steampapps folder above and just renamed them to .old. example below.
There were three files and 2 different locations. First one is C:\AMPDatastore\Instances\TaterTotsCattyHole\palworld\2394010\Pal\Binaries\Win64\steamapps\appmanifest_1007.acf - This was renamed to .oldappmanifest_1007.acf
Second location is as follows. This one may actually have multiple listed in this directory. I did the same to all of them listed here. C:\AMPDatastore\Instances\TaterTotsCattyHole\palworld\2394010\steamapps\appmanifest_228980.acf - Renamed this to .oldappmanifest_228980.acf
Lastly I restarted the computer. Launched AMP. Launched TaterTotsCattyHole. Went to the instance and then the console and verified that no errors came up this time around. Server launched and it didn’t stop like it was previously.
I hope this helps others coming across the same or similar issues.
