Startup Issue with Minecraft - Upon starting fresh Minecraft Java instance it errors out
To reproduce just run any existing, or fresh Minecraft instance end encounter error
It seems like it’s just need a java update in it, updating and or recreating it does not do anything
	java.lang.UnsupportedClassVersionError: net/minecraft/bundler/Main has been compiled by a more recent version of the Java Runtime (class file version 69.0), this version of the Java Runtime only recognizes class file versions up to 65.0
  • Create new Minecraft instance
  • Go into instance and accept EULA
  • Get non working instance
Getting same issue, running docker containers, issue appears to be with the docker image as it only has java 21 installed, latest version is java 25, and that is what the installer is looking for.
Turns out, you can choose which version of java to use in Manage Instance => Configuration => Minecraft. If it is already set to java 25, change it to 21, and switch back to 25, it helped me
