| Product | AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Failed |
this all started with me and my friends being in the server (hosted with hostinger) and it would crash. this was normal and to be expected at first and then a couple days ago the server would crash every around 30-45mins max, and now we’re at the point where the server wont start and there are no clues in the logs and constantly gives me this pop-up when it fails. “Unable to start server.
The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.”
please help i dont really know what im doing so a detailed guide maybe would be helpful?
- attempt to start server
- fails and says “Unable to start server. The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.”
- check logs no fatal errors only warnings and errors
- confused nothing works
