Startup Issue with Minecraft - my server with mods dont start
its a server in 47.2.0 forge for the 1.20.1 is the basic plan
  • I started a server with forge version 47.2.0 for 1.20.1 and put 17 mods inside the folder
  • Then I tried to start the server and it said the following: “The Minecraft server repeatedly failed to start, this is not a fault with AMP - you should check your Minecraft servers log files to find out why it is unable to start.”
  • I checked the console tab but it didn’t seem to have any anomaly.
Just a note, we are not Hostinger, this is the forum for AMP.
I’d suggest first removing the mods to see if the server runs properly, then if it does, add the mods a few at a time to see which one(s) cause it to error. Make sure you’re not loading client-side only mods on the server
