| Product | AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft Bedrock |
| Module | GenericModule |
| Current State | Stopped |
When I try to create a Minecraft bedrock edition server it wont start. It says that my port is already used however when I go to the command prompt it says that nothing else is using that port. I even switched to other ports and am getting the same error code.
Port [XXXXX] may be in use by another process. Free up port and re-run program or adjust server.properties file to use alternate ports for server.
Then the bottom says corrupted double-linked list
- Start New Instance
- Choose Minecraft Bedrock Edition
- Get an error on port
