Startup Issue with Minecraft - Any Minecraft version of forge below 1.21 doesn't start
Product AMP ‘Phobos’ v2.6.2.4 (Mainline)
After successfully installing forge 1.7.10 it failed to start. I have tried other versions of forge and the same problem persist. In console this is the massage it gave me.
Console12:28:25
12:28:26
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:109)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at cpw.mods.fml.relauncher.ServerLaunchWrapper.run(ServerLaunchWrapper.java:43)
at cpw.mods.fml.relauncher.ServerLaunchWrapper.main(ServerLaunchWrapper.java:12)
Caused by: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader ‘bootstrap’)
at net.minecraft.launchwrapper.Launch.(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
… 3 more
  • Create instance
  • Set verison to 1.7.10
  • Update and install
  • Started server
