Startup Issue with Enshrouded - Wine error when starting a newly created instance
Application Enshrouded
Created a new instance.. Updated it and then started it.. The instance failed to start with an error: wine: ‘/AMP/enshrouded/.proton/compatdata/pfx’ is not owned by you
  • Created an Instance
  • Updated the instance
  • Tried to start the instance
what os are you using to host amp on?
Ubuntu v24, should be the latest patch verison, although not sure what the number is… .04 I think…
