Startup Issue with Dune Awakening - Dune Awakening UE5 Maps Not Loading
Application Dune Awakening
Fresh Dune Awakening instance won’t fully start. Backend comes up fine (postgres, both rabbitmq brokers, text-router, mock-k8s, director, gateway all report OK), but all three game maps fail:
ue5-Survival_1: no PID file — service did not start
ue5-Overmap: no PID file — service did not start
ue5-DeepDesert_1: no PID file — service did not start
UE5 game port pool stays at 0/30 on the status page. Everything else listens.
The first-run schema load is throwing an AssertionError and bailing before it builds the base schema. From the prestart section of the console:
[prestart] [INFO] invoking resetdb (loads schema via ToolsDB)…
Traceback (most recent call last):
File “/AMP/duneawakening/extracted/db-utils/root/PSQL/ToolsDB/setupdb.py”, line 56, in _import_module
assert os.path.exists(module_path)
AssertionError
[prestart] [INFO] Database schema loaded: success.
[prestart] [INFO] Seeding world partitions…
ERROR: relation “dune.world_partition” does not exist
Note that prestart prints “Database schema loaded: success” right after the traceback, so the failure is getting swallowed and nothing flags it until the maps don’t come up.
I dug into it. setupdb.py line 55-56 checks for an init.py under settings.module_path. settings.py line 86 sets:
module_path = self.args.schema_path or (config.paths.project / ‘Database’)
The schema package it wants is actually present on disk here:
/AMP/duneawakening/extracted/db-utils/root/DuneSandbox/Database/init.py
So the file exists, but the first-run resetdb call is resolving module_path to a Database dir that doesn’t have it, and the assert fails. Looks like schema_path isn’t being passed, or config.paths.project is resolving to the wrong root, on that initial call.
the base partition seed never runs, so world_partition only ends up with the 3 DLC rows the migrate step force-inserts:
select partition_id, map from dune.world_partition order by partition_id;
partition_id | map
29 | CB_Overland_S_08
30 | CB_Dungeon_ThePit
31 | CB_SurvivalChallenge_Station_15
Partitions 1-28 (Survival_1, Overmap, DeepDesert_1, etc.) are never created, so those maps have nothing to boot against and never write a PID.
What I’ve tried:
Deleted and recreated the instance from scratch
Full clean re-extract (wiped extracted/, re-ran Update)
Full state wipe (removed server/state so first-run creates the dune role and DB from nothing)
Hardware isn’t the issue: AVX2 present, plenty of RAM and disk, all backend services healthy.
Happy to pull any additional logs or run whatever you need.
  • Create Instance
  • Manage Instance
  • Configure Token
  • Run Updates
  • Stop and Start Instance
  • Start Server
@Mike Any insights you could share would be amazing.
Chiming in for just a second here though I have not run a Dune server. Did you see this post?
It mentions issues with running Dune within a container has an issue:
  • The AMP container running the game must be restarted after updating and before starting the game server for the first time. The console will warn you about this.
Just checking if this might be easy fix.
I did. I have made sure to restart the instance after doing the download portion and before starting.
I have also tried this
https://discourse.cubecoders.com/t/dune-awakening-amp-serveron-windows-hangs-on-run-schema-migrations/40441/14
Update:
Resolved it. This was a storage capacity issue. The instance silently failed on extraction and never reported that it didn’t extract successfully. I expanded the drive and everything started after a reinstall.
