| Operating System | Windows - Windows Server 2025 on x86_64 |
| Product | AMP ‘Deimos’ v2.7.2.6 (Mainline) |
| Virtualization | HyperV |
| Application | Conan Exiles |
| Module | GenericModule |
| Running in Container | No |
| Current State | PreStart |
After “Success! App ‘443030’ fully installed.” it keeps saying “Preparing to start” and nothing happens. Console is Clear and AMP Logs says:
quit
Unloading Steam API…OK
[15:17:06] [steamcmdplugin:AMP Info/19] : SteamCMD Update successful
[15:17:07] [Generic:AMP Info/23] : Merging config file ./conan-exiles/443030/ConanSandbox/Saved/Config/WindowsServer/ServerSettings.ini (INI format) using Unicode (UTF-8) encoding.
[15:17:07] [Generic:AMP Warning/9] : Tried to merge config file ./conan-exiles/443030/ConanSandbox/Saved/Config/WindowsServer/Game.ini but the file does not exist.
[15:17:07] [Generic:AMP Warning/9] : Tried to merge config file ./conan-exiles/443030/ConanSandbox/Saved/Config/WindowsServer/Engine.ini but the file does not exist.
[15:17:07] [Generic:AMP Warning/9] : Tried to merge config file ./conan-exiles/443030/ConanSandbox/Saved/Config/LinuxServer/ServerSettings.ini but the file does not exist.
[15:17:07] [Generic:AMP Warning/9] : Tried to merge config file ./conan-exiles/443030/ConanSandbox/Saved/Config/LinuxServer/Game.ini but the file does not exist.
[15:17:07] [Generic:AMP Warning/9] : Tried to merge config file ./conan-exiles/443030/ConanSandbox/Saved/Config/LinuxServer/Engine.ini but the file does not exist.
[15:17:07] [Core:AMP Error/9] : FileNotFoundException
[15:17:07] [Core:AMP Error/9] : [0] (FileNotFoundException) : Couldn’t find the specified application: id
[15:17:07] [Core:AMP Error/9] : at ModuleShared.Utilities.GetUtilityOutput(String ExecutableFile, String Arguments, String WorkingDirectory, String RunAsUser, Boolean IncludeStdErr, Int32 timeoutMs, String input)
at GenericModule.GenericApp.SetupProcess()
at GenericModule.GenericApp.DoAppStartup(Boolean IsUpdating)
at GenericModule.GenericApp.Start()
[15:22:00] [Core Info/13] : Checking for AMP updates…
[15:22:00] [Core Info/13] : AMP is up to date.
Even after creating a new instance of Conan Exiles.
- Create new instance of Conan Exiles Enhanced
- Update server
- Start server
