Startup Issue with Application Deployment - multiple games will not start new instances
Product AMP ‘Proteus’ v2.8.0.6 (Mainline)
ive updated to 2.8.0.6
ive tried starting new valheim instances and they will not start
i have a running satisfactory server so i tried seeing if it was a valheim issue or not and tried to spin up another instance of satisfactory and it will not start up either. tried the same with palworld and same no start
  • start new instance for valheim, wont start
  • try another 2 games, same issue
  • updated amp to 2.8.0.6, still experiencing issues
After update, if you reboot, the ADS doesn’t auto run so you need to
sudo su -l amp
ampinstmgr start ADS01
Then do a force refresh on your Amp screen with Ctrl-f5
Ok, trying this i just get a ADS01 already started message so I’ll just do a wipe and fresh install of everything.
