Startup Issue with Application Deployment - Enshrouded cant install missing docker
Operating System Linux - CachyOS on x86_64
I can’t create an instance of Enshrouded at all. Always gives the same error for missing Docker. Docker is installed and up to date. I am becoming confused on how this is easier. I need a step by step on how to create an instance of Enshrouded as it seems to be listed but not functional. Is it a place holder? Do I need to mod the instance generator?
Update: Turns out, I can’t create any server instance as it kicks the same error for all of them. Missing Docker error.
Update: Resolved the issue. Turned out to be a permission issue. User AMP needed to be elevated and application read write needed to be enabled for Docker and AMP. Then I needed to add exceptions to the firewall, and then it still did not work so I wiped out CashyOS and installed Debian and everything now just works after installing Curl. :frowning: So… yeah.. it works now. Lucky I am running it on a spare pc.
  • Installed Docker on Amp install
  • Installed it again using AI to provide the steps as it seems to be missing.
  • Updated CashyOS before install, again after installing AMP, and updated AMP and rebooted the pc
  • Verified Proton is installed, as is Wine and all other game support offered by CashyOS.
  • Searched forms and can only find snips of information like requires proton, but no info on how to go about it.
