LIM - Failure to make API call to meow01: Connection refused (127.0.0.1:8081)
Exception in API call ADSModule/StartInstance
NullReferenceException
[0] (NullReferenceException) : Object reference not set to an instance of an object.
at InstanceManagerPlugin.AMPInstanceBase.Start()
at ADSModule.WebMethods.StartInstance(String InstanceName, IWebSession session) in C:\TfsAgents\BuildBot2\_work\242\s\GSMyAdmin\ADSModule\WebMethods\WebMethods.cs:line 2366
at GSMyAdmin.WebServer.MethodInvocation.InvokeMethod(String MethodName, JObject Data, HttpContext context, IWebSession Session, WebMethodsBase MethodsClass, IPAddress RealIP)
at GSMyAdmin.WebServer.ApiService.InvokeAPI(HttpContext context, IWebSession session, JObject data, String requestModule, String requestMethod)
Deleting instance 306a55d8-38ea-420e-bcc7-8336e709ab9a
Failed to delete instance Minecraft02: Object reference not set to an instance of an object.
Skipping pull for docker.io/cubecoders/ampbase:java - last pulled 2 minutes ago.
fc3c2a89e7009c49b3329b42b39972f90b30ce11b9da0481090bbba163bc5048
Updating remote source CubeCoders/AMPTemplates:main
Updating existing remote source https://cdn-repo.c7rs.com/AMPTemplates.git...
HEAD is now at 2e0b7ea5 change: Bedrock | Adding "transport" to the server.properties for Nethernet (#2002)
Already up to date.
Skipping pull for docker.io/cubecoders/ampbase:java - last pulled 55 minutes ago.
951f61a1612dba8680d85c5ba7725a5178f8b01f7742b938d320715d2f12d146
I have multiple instances in my files so I’m assuming thats where the issue resides but i cant delete a new instance that I made on accident.
