OS Name/Version: Ubuntu Server 22.04
Product Name/Version: (Always use the full version number - not ‘Latest’) AMP Release “Deimos” v2.7.2.4
Problem Description: Rust will not launch after turning into running as a container
- Step 1 - make rust server not in a container
- Step 2 - after created check “run in container”
- Step 3 - try to start server, will not start nor download files.
readded license key, removed actual amp docker container and reinstalled, turned off firewall, created new docker and amp users. Only will start if taken out of “run in container.”
