OS Name/Version: Ubuntu 22.04.5 LTS (VM on TrueNAS 25.10, KVM)
Product Name/Version: AMP Standard Edition (lifetime), ampinstmgr 2.8.0.10, instances 2.8.0.10, Docker deployment
Problem Description: AMP was having trouble with my palworld server so i decided to upgrade TrueNAS from the older version to the community edition to see if that could help with the constant crashing and stabilitiy issues. Finished that and got AMP and my VM up but am stuck at reactivating my license. Since then my Docker instance PalWorld1001 fails to licence:
[Licencing Error] : Unable to load licence for AMP Standard Edition - NoMatchingMachineId
It never opens its port, so the ADS reports Connection refused (127.0.0.1:8082).
ADS01, which runs natively rather than in Docker, reactivated successfully — Activated successfully / Licence Present: AMP Standard Edition – Lifetime Licence. So the key and activation path both work. Only the Docker instance fails.
- Step 1 - Open instance from ADS Web UI. Says starting instances. Flashes a bit then goes back to Idle or offline.
- Step 2 - Go to Deployment Log get “LIM - Failure to make API call to PalWorld1001: Connection refused (127.0.0.1:8082)”
- Step 3 - Check container log: “Unable to load licence for AMP Standard Edition - NoMatchingMachineId” and never binds its port.
- Step 4 - Run: ampinstmgr reactivate ADS01 Result: “Performing activation… Activated successfully… Licence Present: AMP Standard Edition - Lifetime Licence”. ADS is fine.
- Step 5 - Run: ampinstmgr reactivate PalWorld1001 Result: “Timed out waiting for PalWorld1001’s configuration run to finish; starting it anyway.” No “Activated successfully” line is ever printed.
- Step 6 - Re-check the container log: same NoMatchingMachineId error. Reproducible every time.
Ran `ampinstmgr reactivate PalWorld1001 ` multiple times, with the instance both running and fully stopped beforehand. Always ends in the configuration-run timeout; never prints “Activated successfully”.
Ran “Update All Instances” from the ADS web UI. Containers were recreated from a freshly pulled cubecoders/ampbase:debian. Licence error persisted.
Found a version mismatch: host ampinstmgr was 2.8.0.4 while the containers had moved to 2.8.0.10. Upgraded ampinstmgr to 2.8.0.10 via apt, then ran `ampinstmgr upgradeall`. ADS01 upgraded successfully and, after that, reactivated successfully with a valid lifetime licence. The Docker instance still fails.
Found IPv6 was non-functional on this network and was causing 30-second timeouts on AMP’s outbound calls (`curl -4` returned 200, `curl -6` returned 000; the AMP release manifest fetch was timing out as a result). Added an IPv4 precedence rule to /etc/gai.conf, then disabled IPv6 kernel-wide via sysctl and rebooted. The manifest now fetches successfully (HTTP 200) and AMP’s startup inside the container is dramatically faster. The licence error is unchanged.
Confirmed apt and the CubeCoders repo are healthy; no broken packages.
