Project Zomboid server stuck on starting after backup restore
OS Name/Version: Debian 13
Storage: M.2 SSD
RAM: 180 GB
Product Name/Version: AMP project zomboid b42
Amp version : 2.6.5.2 - 20260128.2
Hello,
I am experiencing an issue with a Project Zomboid server running on CubeCoders AMP.
After restoring a s3backup of the server, the instance gets stuck in the “Starting” state and eventually switches to IDLE.
However, despite AMP indicating that the server is still starting, the server is actually accessible and playable from within the game.
I do not believe this issue is related to a lack of system resources.
It seems like AMP may not correctly detect the server startup state after the backup restoration.
Could you please advise on what might be causing this behavior or how to resynchronize the instance status properly?
Thank you for your assistance.
  • restore a backup of the game from an S3 sources
  • update / check serveur file
  • server stay in starting
reboot the server and the instance → check update → upgrade instance
Cross-post from Discord
