Problem after Update that no oidc License is present
OS Name/Version: Debian13
Product Name/Version: AMP Version v2.8.0.8, built 27/09/2026 01:11
After the Update to the Current Version i get the Error that no license is Presnt but i have a Advanced License and i have reactivated all Instances
  • Step 1 ampinstmgr -P
  • Step 2 ampinstmgr reactivateall
  • Step 3 trying to log in with Authentik
Actions taken to resolve so far: i have reactivated all Instances
I am thankfull for any Help
In ADSs log, does it show that the licence is present?
here are the logfile:
[14:10:08] [System Info/6] : Starting AMP version 2.8.0.10 (Proteus), built 28/10/2026 16:50
[14:10:08] [System Info/6] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[14:10:08] [System Info/6] : Running in a VMware environment.
[14:10:08] [System Warning/6] : Current time zone is set to Mitteleuropäische Normalzeit - It is recommended you switch to UTC+0 to avoid time-zone related issues
[14:10:08] [System Info/6] : OS: Linux / x86_64
[14:10:08] [System Info/6] : CPU: Intel(R) Core™ i7-8700 CPU @ 3.20GHz (2C/2T)
[14:10:08] [System Info/6] : RAM: 3917MB
[14:10:08] [System Info/6] : AMP Instance ID: b9a88eee-4b60-4d85-a367-be6f8c6a110d
[14:10:08] [Licencing Error/6] : Unable to load licence for AMP Advanced Edition - NoMatchingMachineId
[14:10:08] [System Info/6] : Loaded ADSModule version 2.8.0.10 by CubeCoders Limited
[14:10:08] [System Info/6] : Loaded FileManagerPlugin by CubeCoders Limited
[14:10:08] [System Info/6] : Loaded EmailSenderPlugin by CubeCoders Limited
[14:10:08] [System Info/6] : Loaded WebRequestPlugin by CubeCoders Limited
[14:10:09] [System Info/6] : Loaded WebhookPlugin by CubeCoders Limited
[14:10:09] [System Info/6] : Loaded CommonCorePlugin by CubeCoders Limited
[14:10:09] [System Info/6] : Loaded StorePlugin by StorePlugin
[14:10:09] [System Info/6] : ADSModule requests dependency InstanceManagerPlugin…
[14:10:09] [System Info/6] : Loaded InstanceManagerPlugin by CubeCoders Limited
[14:10:09] [System Info/6] : ADSModule requests dependency SystemUserManagerPlugin…
[14:10:09] [System Info/6] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[14:10:09] [System Warning/9] : Shared roles were present, but the licence does not permit this feature. Please re-activate with a licence that includes this feature.
[14:10:09] [System Info/9] : Loaded steamcmdplugin by CubeCoders Limited
[14:10:09] [System Info/9] : Metrics server started OK on port 12820
[14:10:09] [System Info/9] : ADS startup complete in 76ms
[14:10:09] [System Info/4] : Updating remote source CubeCoders/AMPTemplates:main
[14:10:09] [System Info/4] : Updating existing remote source https://cdn-repo.c7rs.com/AMPTemplates.git…
[14:10:09] [System Activity/6] : Authentication token 8f5c69ff126c for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
HEAD ist jetzt bei 09725da Valheim - Add 1.0 settings, GC engine tuning, CLI params, and reorganize settings (#1999)
[14:10:09] [System Activity/4] : Authentication token 7b5413d62ce9 for AMP_SYSTEM requested by CreateReauthCallback on behalf of INTERNAL
[14:10:09] [System Info/6] : Failed to update WTH-AMP-LI-01 - The remote server rejected the login credentials: Login Server Unavailable
[14:10:09] [System Activity/6] : Authentication token bba0813d4b71 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
[14:10:09] [System Activity/4] : Authentication token dfccac3cb27e for AMP_SYSTEM requested by CreateReauthCallback on behalf of INTERNAL
[14:10:09] [System Info/6] : Failed to update WTH-AMP-WIN-01 - The remote server rejected the login credentials: Login Server Unavailable
[14:10:09] [System Notice/9] : Using keypair with fingerprint 4yPgktC+uPGtfEkgrYD2p8Ua7yMCUXGhR06U4yFTopg=
Bereits aktuell.
[14:10:09] [System Info/13] : SFTP Server started on 0.0.0.0:2223
[14:10:11] [Core Info/13] : Webserver started on http://0.0.0.0:8080
[14:10:11] [System Info/13] : Checking for AMP updates…
[14:10:11] [System Activity/9] : Authentication token 769da018b785 for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
[14:10:11] [System Info/6] : AMP is up to date.
[14:10:11] [System Activity/4] : Authentication token 0dc72504e89b for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of INTERNAL
run ampinstmgr reactivate ADS as the amp user.
I have already done this step as amp user, for more context it is a Hyper-v vm that i have converted to kcm/qemu
