Palworld Modded. disable settings check
I am running a modded Palworld server. One of the mods allows me to increase the amount of bases. however you have to define the amount in the ini file. when running the server directly i can increase it to 30+ with no issues however with amp it tells me the max is 10 and will reset the setting to 10 if i attempt to set it higher. is there a way to disable this check?
I will update the template to allow it. Which setting specifically?
