Open ports with hostinger
OS Name/Version:
Debian GNU/Linux 11
AMP 2.4.4
What are some open ports I can use with hostinger application. Im making a Minecraft Server and Votifier doesn’t seem to be working, I can’t think of anything else that would be the problem other than ports.
provides syntax highlighting.
  • Step 1
  • Step 2
  • Step 3
If you go to the Status tab inside your instance it should show what ports are used. Otherwise, you have to reach out to Hostinger support if their ports aren’t showing as opened.
