Hi. After the the Update I can’t start any Game Servers.
re-adding the licence in the GUI or via ampinstmgr reactivate
doesn’t seems to help
[14:33:35] [Core Error] : No valid AMP licence was found. Please run `ampinstmgr reactivate Cracktorio01` to reactivate this instance.
CubeCoders AMP 💻amp@gameserver 📁~ ampinstmgr reactivate Cracktorio01
[Info] AMP Instance Manager v2.3.2.8 built 28/03/2022 15:22
Please enter value for Licence Key
XXXX
[Warning] Instances may not be created or modified using this tool while ADS is running. Either make the changes via ADS itself or stop ADS before making changes.
[Warning] You can do this by running 'ampinstmgr stop ADS01'
CubeCoders AMP 💻amp@gameserver 📁~ ampinstmgr stop ADS01
[Info] Stopping Instance: 'ADS01'
[Info] Stopping instance ADS01...
[Info] Requesting soft-stop...
[Info] Waiting for instance to stop...
[Info] Instance ADS01 has stopped.
XXX
[Info] Checking licence key...
[Info] Licence Type: AMP Network Standard
[Info] Current Usage: 3
[Info] Reactivating instance Cracktorio01...
[Info] su: ignoring --preserve-environment, it's mutually exclusive with --login
[Info]
[14:34:38] [Core Info] : Starting AMP version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[Info] [14:34:38] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[Info] [14:34:38] [Core Info] : Running in a Docker environment.
[Info] [14:34:38] [Core Info] : OS: Linux / x86_64
[Info] [14:34:38] [Core Info] : CPU: AMD Ryzen 9 3900X 12-Core Processor (4C/8T)
[Info] [14:34:38] [Core Info] : AMP Instance ID: XX
[Info] [14:34:38] [ModuleLoader Info] : Loaded FactorioModule version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[Info] [14:34:38] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[Info] [14:34:38] [Core Info] : Performing activation, please wait...
[Info] [14:34:39] [Core Info] : Activated successfully.
[Info] [14:34:39] [Core Info] : Licence Present: AMP Network Standard Edition (Licenced to XXX)
[Info] [14:34:39] [Core Info] : -configonly specified or activation performed. Saving settings and shutting down. This is perfectly normal.
[Info]
[Info] Done.
CubeCoders AMP 💻amp@gameserver 📁~ ampinstmgr start ADS01
[Info] Starting Instance: 'ADS01'
[Notice] AMP instance ADS01 is now running.
[Info] You can browse to this instance at http://192.168.1.199:8080/
[Info] Instance started in new session. Run 'ampinstmgr View ADS01' to view this instances live output.
but same as before:
[14:36:34] [Core Info] : Starting AMP version 2.4.0.4 (Halimede), built 10/09/2022 16:30
[14:36:34] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[14:36:34] [Core Info] : Running in a Docker environment.
[14:36:34] [Core Info] : OS: Linux / x86_64
[14:36:34] [Core Info] : CPU: AMD Ryzen 9 3900X 12-Core Processor (4C/8T)
[14:36:34] [Core Info] : AMP Instance ID: b0c8521d-033c-4951-86a5-03fa6a494c1a
[14:36:34] [ModuleLoader Info] : Loaded FactorioModule version 1.0.0.0 by CubeCoders Limited
[14:36:34] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[14:36:34] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[14:36:34] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[14:36:34] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[14:36:34] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[14:36:34] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[14:36:35] [FileManager Notice] : Using keypair with fingerprint AViZ/Kj0TZzjABijdcicsdSETPmyAMPkclFnrjnBPRM=
[14:36:35] [FileManager Info] : SFTP Server started on 0.0.0.0:2233
[14:36:35] [Core Error] : No valid AMP licence was found. Please run `ampinstmgr reactivate Cracktorio01` to reactivate this instance.
