No such instance matching name
im not shure how to fix the top part i have tried everything but nothing works
You’ve posted very little information - please tell us what OS you’re running, what command you ran, what exact output you got. Screenshot of the terminal if applicable.
windows for os
the command i ran= “ampinstmgr resetlogin”
and the outout i got was= “No such instance matching name”
What’s the output of ampinstmgr status
? Show a screenshot of the command prompt (Alt+Printscreen to capture it, CTRL+V directly into here)
Probably the instance name should be ADS01
. Also that is not the screenshot Mike asked for.
