Minecraft Instance automatically stopping
OS Name/Version:
|OS|Linux|
|Platform|Debian GNU/Linux 10|
Product Name/Version:
|Application Name|AMP|
|Application Version|2.4.4.0|
Minecraft dedicated server being run through AMP using Hostinger will not stay active after AMP update to 2.4.4.0
  • Click start instance
  • No further actions. Instance will say running for between 1-2 minutes then will revert to offline status.
Have attempted to restart AMP, update AMP and the individual instance, as well as review the logs but I’m not familiar with Linux. Part of the reason my friends and I are paying Hostinger, but they’re not providing any helpful information.
The console gives the notification LIM - Failure to make API call to TheBlockheads01: Connection refused.
When I look at the instance logs, I see the following:
[Logger Error] : No valid AMP license was found. Please open a shell as the ‘amp’ user and run ‘ampinstmgr reactivate ServerName’ to reactivate this instance
I can’t figure out how to do this however.
I apologize if this is formatted incorrectly since this is not something I’m familiar with. Any help is appreciated.
you need to use putty login as root then su -l amp > change user then ‘ampinstmgr reactivate ServerName’ then reinsert your license key
hope this helps
As far as I know you have to give that error to Hostinger support since they own the AMP license.
I was able to follow these steps up until the reinserting license key part. I’m getting a message that the license key does not exist, so I’m not sure where to get the correct one.
Where did you get a key from? Like I said above, Hostinger controls the key as far as I know. Their support would have to do the reactivation for you.
I found a couple of files in the directory labeled as License, so I was trying to input those. I think you’re right about needing to contact Hostinger. It’s just the first time I contacted them they weren’t helpful at all so hopefully this time it will go better.
thought u purchased your own license key
