Minecraft Geyser Config Not Pointing to Updated Playit.gg Tunnel
OS Name/Version: Linux - Debian GNU/Linux 13 on x86_64
Product Name/Version: AMP Proteus v2.8.0.10
Problem Description: Updated my Geyser config.yml file with new nethernet requirements and the server keeps pointing to an old playit.gg tunnel and I believe this is why I cannot connect to my server on Bedrock. Connection to java tunnel works fine but keep getting “terracotta” error when trying Bedrock. The “shrimp-wifi.tun.ply.gg:19132” is the old tunnel.
NXS: IPv4 is available for player connections.
Registered with the external signaling service. Players can join at https://shrimp-wifi.tun.ply.gg:19132 (instance ins_Tb82Qi_jTizMyqWBb6XyQg).
  • Create a "Minecraft Bedrock (NetherNet) tunnel on playit.gg.
  • Update the Geyser config.yml file with new info according to NetherNet Configuration Help prompt. (sections: bedrock - advertise-addesses, transport, clone-remote-port, signaling - mode, stun discovery, - nxs: token, endpoint.)
  • Restart server and check console for domain that players can join at. This should match the playit.gg tunnel address.
  • Delete the tunnel on playit.gg and create and new Minecraft Bedrock (NetherNet) tunnel.
  • Update the token in the Geyser config.yml file to correspond with new tunnel token.
  • Restart server and check console for updated tunnel address, but still points to old tunnel that doesn’t exist anymore.
  • Updated the token in the config.yml file to the new tunnel’s token.
  • Double checked the rest of the settings in the yml file for consistency.
  • Watched a YouTube video to see if I was overlooking something.
  • Tested Bedrock connection on Mobile device and PC and both resulted in the “Terracotta” error message.
  • Can’t get old tunnel name back on playit.gg because the names are randomly generated.
  • Geyser mod is updated to latest version, build 1280.
  • Floodgate mod is updated to latest version, 2.2.7 b69.
  • Fabric-API is updated to latest stable release version, 0.165.0 +26.3.
This is my first time using playit.gg for tunnels so I apologize for anything I may be overlooking. I noticed the token ID changed when creating the new tunnel so thought that was the reason why the console was still pointing to the old domain but after updating it, it’s still not showing the new one.
Any help with this is greatly appreciated! Thank You!
