Minecraft crashing on launch
OS Name/Version: Windows 10
Product Name/Version: AMP version 2.8.0.4 - 20260724.1
i am getting an issue with minecraft crashing almost instantly and refusing to start
```vbnet
WARNING: A terminally deprecated method in sun.misc.Unsafe has been called
WARNING: sun.misc.Unsafe::objectFieldOffset has been called by cpw.mods.jarhandling.impl.SecureJarVerifier$UnsafeAccessor (file:/G:/AMPDatastore/Instances/test01/Minecraft/libraries/cpw/mods/securejarhandler/3.0.8/securejarhandler-3.0.8.jar)
WARNING: Please consider reporting this to the maintainers of class cpw.mods.jarhandling.impl.SecureJarVerifier$UnsafeAccessor
WARNING: sun.misc.Unsafe::objectFieldOffset will be removed in a future release
[11:55:43.407] [main/INFO]: ModLauncher running: args [--launchTarget, forgeserver, --fml.neoForgeVersion, 21.1.248, --fml.fmlVersion, 4.0.43, --fml.mcVersion, 1.21.1, --fml.neoFormVersion, 20240808.144430]
[11:55:43.409] [main/INFO]: JVM identified as Oracle Corporation Java HotSpot(TM) 64-Bit Server VM 25.0.3+9-LTS-195
[11:55:43.410] [main/INFO]: ModLauncher 11.0.5+main.901c6ea8 starting: java version 25.0.3 by Oracle Corporation; OS Windows 10 arch amd64 version 10.0
[11:55:43.467] [main/INFO]: ImmediateWindowProvider not loading because launch target is forgeserver
[11:55:43.491] [main/INFO]: SpongePowered MIXIN Subsystem Version=0.8.7 Source=union:/G:/AMPDatastore/Instances/test01/Minecraft/libraries/net/fabricmc/sponge-mixin/0.15.2+mixin.0.8.7/sponge-mixin-0.15.2+mixin.0.8.7.jar%2373!/ Service=ModLauncher Env=SERVER
[11:55:43.644] [main/INFO]: Found mod file "server-1.21.1-20240808.144430-srg.jar" [locator: production server provider +net.neoforged:neoforge:21.1.248:server]
[11:55:43.657] [main/INFO]: Found mod file "neoforge-21.1.248-universal.jar" [locator: PathBasedLocator[name=neoforge, paths=[libraries\net\neoforged\neoforge\21.1.248\neoforge-21.1.248-universal.jar]], reader: mod manifest]
[11:55:43.715] [main/INFO]: Found 2 dependencies adding them to mods collection
[11:55:43.715] [main/INFO]: Found gamelibrary file "mixinextras-neoforge-0.5.3.jar" [parent: neoforge-21.1.248-universal.jar, locator: jarinjar, reader: mod manifest]
[11:55:43.715] [main/INFO]: Found library file "net.neoforged.neoforge-coremods-21.1.248.jar" [parent: neoforge-21.1.248-universal.jar, locator: jarinjar, reader: mod manifest]
[11:55:43.716] [main/INFO] [loading.moddiscovery.ModDiscoverer/]:
     Mod List:
		Name Version (Mod Id)
		Minecraft 1.21.1 (minecraft)
		NeoForge 21.1.248 (neoforge)
[11:55:43.918] [main/INFO]: Launching target 'forgeserver' with arguments []
WARN StatusConsoleListener Advanced terminal features are not available in this environment
WARNING: A restricted method in java.lang.System has been called
WARNING: java.lang.System::load has been called by com.sun.jna.Native in module com.sun.jna (union:/G:/AMPDatastore/Instances/test01/Minecraft/libraries/net/java/dev/jna/jna/5.14.0/jna-5.14.0.jar%23112!/)
WARNING: Use --enable-native-access=com.sun.jna to avoid a warning for callers in this module
WARNING: Restricted methods will be blocked in a future release unless native access is enabled
  • create new instance
  • launch server
  • error appears
it gives this error no matter what kind of server type (fabric, neoforge, official). i have tried different versions and some like official servers will launch but still give the error and neoforge will not launch at all most of the time. ive tried fresh instances and downloads and also reinstalling amp entirely. i asked for help in the neoforge discord server and one of the moderators there said it seemed to be an issue with corrupted minecraft files but im not really sure how to fix that or what to reinstall
