Minecraft - Backup schedule not working
Product AMP ‘Phobos’ v2.6.2.6 (Mainline)
Backup is not working
a schedule is made to make a backup, but it never takes one
  • set up schedule
  • back up is tried
  • never saved
If you take one manually does it do it?
nope not even a manual backup will work
Check that instances log to see if it says what the problem is.
it doesnt say any errors but its attempting to create the back up but never saves one
That’s the audit log - the log files are accessible via the top level file manager in the AMP_Logs directory for each instance.
