I have one Advanced License, and i have two questions:
Do i need another license to add additional physical server, or as long as i don’t run over 50 instances i don’t need new licences, and licence resrticted only by instance count, not physical server count?
Second question is, can i somehow determine what DNS adresses(IP’s?) it uses? My internet isn’t very reliable, so i must forward geodata requests to another gateway/VPN
AMP is only licenced by instance count - not server count. You could have 50 servers with 1 instance each if you wanted.
Second question I’m not sure I understand what you’re asking - but AMP gets the IP addresses from the log output of the game server. So whatever that shows is what AMP works with.
About second question, i talked about Geoip, well every instance have analytics tab, if you enable it, it has some internal geoip database, based on which it can determine where user was from based on client ip and since it could not update database (ISP messing with traffic), i have only “no data" instead of countries
