I got a mail that saying that i’m using 25 instances but i only have 3 on the server. But i had to reactivate them several times for some reason some time ago then instances didn’t startup because the licence key wasn’t there anymore on each instance but it was the same old instances that i had used.
Make sure you login to your account at CubeCoders and look at where it thinks the licence is being used and that the usage is where you expect. If it isn’t you may need to ask for a reset.
