Well that’s the Instance log before the crash:
AMPLOG 2023-05-28 00-25-19.log Download Link
This is the Instance Log right after the crash:
[04:10:56] [Logger Info] : Loading locale data for xx from xx.json...
[04:10:56] [Logger Info] : Starting AMP version 2.4.4.0 (Decadeus), built 17/05/2023 17:54
[04:10:56] [Logger Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[04:10:56] [Logger Info] : Running in a Docker environment.
[04:10:56] [Logger Info] : OS: Linux / x86_64
[04:10:56] [Logger Info] : CPU: 11th Gen Intel(R) Core(TM) i5-11600 @ 2.80GHz (6C/12T)
[04:10:56] [Logger Info] : RAM: 64119MB
[04:10:56] [Logger Info] : AMP Instance ID: 6067ff72-5f91-4b87-9a9a-d150a2b363e4
[04:10:56] [Logger Error] : Unable to load licence for AMP Network Standard - NoMatchingMachineId
[04:10:56] [Logger Debug] : Using remote login server http://localhost:8080/
[04:10:56] [Logger Debug] : Starting process /usr/bin/arch
[04:10:56] [Logger Debug] : Started process with ID 44
[04:10:56] [Logger Debug] : Starting process /usr/bin/lscpu
[04:10:56] [Logger Debug] : Started process with ID 45
[04:10:56] [Logger Debug] : Starting process /usr/bin/ldd
[04:10:56] [Logger Debug] : Arguments: --version
[04:10:56] [Logger Debug] : Started process with ID 46
[04:10:56] [Logger Debug] : Performing signature verification for GenericModule...
[04:10:57] [Logger Debug] : Performing signature verification for steamcmdplugin...
[04:10:57] [Logger Info] : 3 Legacy ports migrated.
[04:10:57] [Logger Debug] : Performing signature verification for RCONPlugin...
[04:10:57] [Logger Info] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
[04:10:57] [Logger Info] : Metrics publishing is enabled at udp://localhost:12820.
[04:10:57] [Logger Debug] : Performing signature verification for FileManagerPlugin...
[04:10:57] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[04:10:57] [Logger Debug] : Performing signature verification for EmailSenderPlugin...
[04:10:57] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[04:10:57] [Logger Debug] : Performing signature verification for WebRequestPlugin...
[04:10:57] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[04:10:57] [Logger Debug] : Performing signature verification for LocalFileBackupPlugin...
[04:10:57] [Logger Debug] : Read manifests for 0 backups.
[04:10:57] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[04:10:57] [Logger Debug] : Performing signature verification for CommonCorePlugin...
[04:10:57] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[04:10:57] [Logger Info] : GenericModule requests dependency steamcmdplugin...
[04:10:57] [Logger Info] : Loaded steamcmdplugin by CubeCoders Limited
[04:10:57] [Logger Info] : GenericModule requests dependency RCONPlugin...
[04:10:57] [Logger Info] : Loaded RCONPlugin by CubeCoders Limited
[04:10:57] [Logger Warning] : Schedule trigger 79059317-96cb-42a7-8eb4-207388f32127 has a mismatched ID!
[04:10:57] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair...
[04:10:57] [Logger Notice] : Generated new keypair with fingerprint biRD1KYtr5YT0uSrNWJLxg+8/KK8SaY/5EhKPpNdsqo=
[04:10:57] [Logger Notice] : Using keypair with fingerprint biRD1KYtr5YT0uSrNWJLxg+8/KK8SaY/5EhKPpNdsqo=
[04:10:57] [Logger Info] : SFTP Server started on 0.0.0.0:2226
[04:10:57] [Logger Error] : No valid AMP licence was found. Please open a shell as the 'amp' user and run `ampinstmgr reactivate JensServer01` to reactivate this instance.
This is the panels log:
[04:10:49] [Logger Info] : Loading locale data for xx from xx.json...
[04:10:49] [Logger Info] : Starting AMP version 2.4.4.0 (Decadeus), built 17/05/2023 17:54
[04:10:49] [Logger Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[04:10:49] [Logger Warning] : Current time zone is set to CET - It is recommended you switch to UTC+0 to avoid time-zone related issues
[04:10:49] [Logger Info] : OS: Linux / x86_64
[04:10:49] [Logger Info] : CPU: 11th Gen Intel(R) Core(TM) i5-11600 @ 2.80GHz (6C/12T)
[04:10:49] [Logger Info] : RAM: 64119MB
[04:10:49] [Logger Info] : AMP Instance ID: 189d3822-122e-4624-b914-6a4e4ad432df
[04:10:49] [Logger Info] : Loaded ADSModule version 1.0.0.0 by CubeCoders Limited
[04:10:49] [Logger Info] : Loaded FileManagerPlugin by CubeCoders Limited
[04:10:49] [Logger Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[04:10:49] [Logger Info] : Loaded WebRequestPlugin by CubeCoders Limited
[04:10:49] [Logger Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[04:10:49] [Logger Info] : Loaded CommonCorePlugin by CubeCoders Limited
[04:10:49] [Logger Info] : ADSModule requests dependency InstanceManagerPlugin...
[04:10:50] [Logger Info] : Loaded InstanceManagerPlugin by CubeCoders Limited
[04:10:50] [Logger Info] : ADSModule requests dependency SystemUserManagerPlugin...
[04:10:50] [Logger Info] : Loaded SystemUserManagerPlugin by CubeCoders Limited
[04:10:50] [Logger Info] : Loaded steamcmdplugin by CubeCoders Limited
[04:10:50] [Logger Info] : Metrics server started OK on port 12820
[04:10:50] [Logger Info] : ADS startup complete in 120ms
[04:10:50] [Logger Info] : Updating remote source CubeCoders/AMPTemplates
[04:10:50] [Logger Info] : Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git...
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint: git config pull.rebase false # merge (the default strategy)
hint: git config pull.rebase true # rebase
hint: git config pull.ff only # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
[04:10:50] [FileManager Notice] : No SSH keypair available for embedded server, generating new keypair...
[04:10:50] [Logger Notice] : Generated new keypair with fingerprint rfw4Y8xV+ullfL/CgABhHLjKfh3ZSJJmi0g5zI7RQL4=
[04:10:50] [Logger Notice] : Using keypair with fingerprint rfw4Y8xV+ullfL/CgABhHLjKfh3ZSJJmi0g5zI7RQL4=
[04:10:50] [Logger Info] : SFTP Server started on 0.0.0.0:2223
[04:10:50] [Webserver Info] : Websockets are enabled.
[04:10:50] [Logger Info] : Webserver started on http://0.0.0.0:8080
[04:10:50] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[04:10:50] [Core Info] : Checking for AMP updates...
[04:10:50] [Logger Info] : Startup mode is StartApplication.
Already up to date.
[04:10:50] [Core Info] : AMP is up-to-date.
[04:10:55] [InstanceManager Info] : docker: Error response from daemon: Conflict. The container name "/AMP_JensServer01" is already in use by container "b9dd114277271dfef7f120e7b05f2414a522da7b9cd207ed923a718ac76e7bf4". You have to remove (or rename) that container to be able to reuse that name.
[04:10:55] [InstanceManager Info] : See 'docker run --help'.
If you need anything else please tell me.
