OS Name/Version: AMP Release “Triton”
Product Name/Version: v2.3.4.3, built 12/07/2022 13:00
I was able to access the webserver for an instance at <AMP_Inst_IP>:8084, but now I am no longer able to. I can only access the AMP ADS instance (at <AMP_Inst_IP>:8080) but I cannot access the Minecraft webserver instance at port <AMP_Inst_IP>:8084. I did recently change the IP address of the ADS server and issued the command ampinstmgr repairauth standalone http://localhost:8080
to fix the auth server, but after issuing that command I tested my instance webservers and they were all accessible. I’m not sure what would have changed after that.
Everything looks good in the AMPConfig.ini and instances.json files. How can I debug this?
I’ve verified IP addresses look good. I can manage the instance via Instance->Manage. I’ve verified the endpoint IP address is set to 0.0.0.0, and webserver port is indeed set to 8084 (per Instances.json).
