OS Name/Version:
provides syntax highlighting.
Thought I could save some time by Purchasing , installing this program as I work 60-70 hours a week . Yeah well does not work period , as I have installed OS 3 times along with the AMP program and again same shite won’t install an instance because of no dockers, which I chose on the install , chose y on everything but still does not work .
Did some research and tried a few things still no go , did I just waste $20 ? no big deal but the big deal is I want to install a few games to play with Co-workers . Yeah AMP is not helping at all , will not install anything other than error messages .
Hi @D_O_B - you’ve not included any information that actually tells us what problem you’re having, what you’re trying to do, or even what OS you’re running on. Please fill in the template and give us more information on exactly what’s wrong so we can assist you.
Sorry Gents and do really appreciate responses , when time presents itself I will reply with the information. After looking through the games most of which run native in Windblows I installed AMP on a Windows box instead . Got the game (Enshrouded) running just could not get the server cfg to stick kept reverting back to default AMP server . Once again I thank you but will not waste anymore of your time until I have time to truly engage. I did start the game from the install folder and it works perfectly ,(after editing the json cfg) but would really like to manage with this slick manager. Thanks again
Thanks again .
I did many times but it would never stick it would always re-write or revert to the AMP server , I would loose everything I changed in the file manager and then Saved . Might be missing something but the only way it would stick is if I edited the . json file and started the game from the exe. in the instance directory.
Again, you’re not supposed to edit config files nor do you use the file manager. You use the Configuration section on the left hand side and adjust the game settings via the user interface. You can also use the search box in the top right of AMP to find any given setting.
