Hiii! I would like to request an option in AMP to configure the public IP address and external UDP port mappings used by Minecraft Bedrock’s NetherNet transport.
Currently, AMP automatically generates the server-udp-ports property using the $UDPTransportPortRange variable. However, when hosting Minecraft Bedrock behind NAT, the generated configuration may not provide the public IP information required for external clients to connect successfully.
Environment
AMP Version: 2.8.0.10
Module: GenericModule (Minecraft Bedrock)
Operating System: Ubuntu Linux
Deployment: AMP instances running in Docker containers
Virtualization: Proxmox
Firewall/Router: OPNsense
Minecraft Transport: NetherNet (WebRTC)
Network: Server behind NAT with UDP port forwarding
Issue Encountered
I host multiple Minecraft Bedrock servers using AMP.
After switching to NetherNet, clients on my local network could connect successfully, and external clients could retrieve the server information through the TCP signaling port. However, external clients could not successfully join the world.
Packet captures showed that the TCP connection was established, but the expected incoming NetherNet UDP traffic was not reaching the server.
AMP was automatically generating the following configuration for one of my instances:
server-udp-ports=20000-20019
I discovered that the setting was generated through the following mapping in metaconfig.json:
"server-udp-ports=": "$UDPTransportPortRange"
Working Solution
I modified the mapping to explicitly specify the public IPv4 address and external-to-internal UDP port range:
"server-udp-ports=": "PUBLIC_IP:20000-20019:20000-20019"
After restarting the AMP instance, the resulting Minecraft configuration became:
server-udp-ports=PUBLIC_IP:20000-20019:20000-20019
External clients were then able to connect successfully over cellular data.
I applied the same configuration approach to four additional Minecraft Bedrock instances, each using its own UDP port range.
Requested Feature
It would be helpful if AMP provided the following options in the Minecraft Bedrock instance configuration:
Public IP / External Address: Allow users to specify the public IPv4 address used for NetherNet connections.
External UDP Port Mapping: Allow users to configure external-to-internal UDP port mappings while preserving AMP’s port allocation system.
Automatic Configuration Generation: Generate the appropriate
server-udp-portsproperty without requiring manual changes tometaconfig.json. -
Dynamic Public IP Support (Optional): Support hostname-based configuration or automatic public-IP detection and updates for users with dynamic WAN addresses.
Ideally, these settings would be available in the existing Network and Ports section.
Expected Behavior
AMP should allow administrators hosting Minecraft Bedrock behind NAT to explicitly configure the public address and UDP port mappings used by NetherNet, while continuing to manage the allocated port ranges automatically.
Additional Notes
AMP already provides an Advertised Connection Address setting, but it does not appear to control the public IP used in the generated NetherNet UDP transport configuration.
A dedicated NetherNet public-address setting would make hosting Minecraft Bedrock behind NAT easier and avoid requiring manual edits to AMP-managed configuration files.
Thank you for considering this feature.
