Failure with Application Deployment - Unable to create Dune instance
Operating System Windows - Windows 10 Professionnel on x86_64
Product AMPService ‘Proteus’ v2.8.0.4 (Mainline)
Instructions : Configuring AMP to use Docker/Podman for instances
When i click on Create Instance, i get the message below :
Unable to complete task
This task could not be completed: Create instance - Dune Awakening - State: 3.
This instance either requires or has been configured to use containers, but Podman was not found on the system.
  • followed the instructions to get Dockers working (WSL 2)
  • configured AMP Instance deployment settings
  • select Dune Awakening
  • click on Create Instance
According to the error, you are using podman, not docker, but it isn’t installed. Install podmanand retry.
It’s resolved ! I was running a “per-user” installation of Docker, but you need to install the “all users”. My bad !
