Error with licensing of ADS01
installed On Ubuntu Linux Server 20.04.6
OS Name/Version: AMP Instance Manager v2.4.6.6 built
Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Problem Description: error licensing
19:14:28
Managed remote instance srcds01 at http://127.0.0.1:8082/
Authentication token for admin requested by ManageInstance on behalf of admin
19:14:28
LIM - Failure to make API call to srcds01: Connection refused
:admin
19:14:46
Non-managed instances exist, autoconfigure cannot guarentee that the configuration is valid!
Failed to autoconfigure instance : There are no available AMP service ports.
Create Instance Failed: There are no available AMP service ports.
19:15:00
Exception executing global interval tick. Object reference not set to an instance of an object
:admin
19:15:11
Managed remote instance ArmaReforger01 at http://127.0.0.1:8081/
19:15:12
LIM - Failure to make API call to ArmaReforger01: Connection refused
:admin
19:15:27
19:15:27
:admin
19:15:32
19:16:00
19:17:00
:admin
19:17:07
19:18:00
:admin
19:18:26
Stopping instance srcds01…
19:18:31
Instance srcds01 has stopped.
19:18:42
Deleting instance 5065754a-5717-402d-85c9-c7d13b9e64d2
19:19:07
Deleting instance d19a3d44-e9b7-4a0f-9c68-5c937711b36e
19:19:17
19:19:54
Changing setting ADSModule.Networking.AMPPortRanges to
19:19:58
Changing setting ADSModule.Networking.DockerExternalIPBinding to 192.168.1.113
19:20:28
Changing setting ADSModule.Networking.DefaultIPBinding to 0.0.0.0
19:20:31
Changing setting ADSModule.Networking.DefaultAppIPBinding to 0.0.0.0
19:20:33
Changing setting ADSModule.Networking.DockerExternalIPBinding to 0.0.0.0
19:20:45
AMP Service port ranges have not been specified, using any available…
19:20:49
ea5bffcdba119eb34999b58c4ed6690ab86e074069045da60e360ca33f07eb23
19:20:54
c853697cc176776440f920ddec132b5a61dce712687bc19c8f81ae1eabaf9d94
19:21:06
086cb733c27185d91c715ce3561dce6112be6809babcc8e1424db2bb5fc76c08
Managed remote instance srcds01 at http://127.0.0.1:8081/
19:21:07
:admin
19:22:05
Upgrading instance srcds01
19:22:08
Using default tag: latest
19:22:09
latest: Pulling from cubecoders/ampbase
Digest: sha256:e836dc28133d1386e6b4f1c81b6767945a4909eef095b87ed480c9f371978c0a
Status: Image is up to date for cubecoders/ampbase:latest
docker.io/cubecoders/ampbase:latest
19:22:25
9d600d29d5ee720f31a4def71e2d7fdb200a34caf48e19a80d6c58297e849804
19:23:36
Changing setting ADSModule.Networking.AMPPortRanges to [“8080:8180”]
This is nothing to do with your licencing. You’ve messed around with your configuration. Make sure that there are service ports available under the Networking configuration.
Also take proper screenshots please rather than using your phone.
