Dune Awakening Connection Issue
First time using Amp. Managed to get a Dune server running. Was able to create a character but can’t connect to the server. Server shows in Dune browser. I have Amp running on Ubuntu. I’ve forwarded all the ports. Not sure what’s missing.
make sure you have updated it. you need to shutdown/stop the entire instance and update that way vs how you would normally update an instance. This is due to how Dune servers work.
I’ve done that and it times out when trying to connect.
I had the same problem as you, I was running the server on an Ubuntu VPS with 24Gb of ram, I tried increasing it to 46Gb and now I can play without any problem, I don’t know if this can help you
Mine is an Ubuntu vm. I’ve got 8 cores dedicated to it as well as 64gb of ram. Meets all the requirements.
