OS Name/Version: Windows 10 Professional
Product Name/Version: 2.5.0.12 - 20240531.1, Docker instance (Minecraft Bedrock) 2.5.0.12 (Callisto), built 31/05/2024
Problem Description: Docker instance appears to not be able to report metrics to AMP running outside of docker.
2024-05-31 15:46:47 [Info] AMPStart for Docker - v23.07.1
2024-05-31 15:46:47 [Info] Performing first-time container setup…
2024-05-31 15:46:47 [Info] Container setup complete.
2024-05-31 15:46:47 [Info] No missing dependencies to install.
2024-05-31 15:46:48 [Info] AMP Instance Manager v2.5.0.4 built 04/04/2024 18:29
2024-05-31 15:46:48 [Info] Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
2024-05-31 15:46:54 [Info] Certificates have been synced.
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : Starting AMP version 2.5.0.12 (Callisto), built 31/05/2024 14:46
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : Running in a Docker environment.
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : OS: Linux / x86_64
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : CPU: Intel(R) Xeon(R) Platinum 8173M CPU @ 2.00GHz (28C/56T)
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : RAM: 64109MB
2024-05-31 15:46:59 [20:46:59] [Core Info/1] : AMP Instance ID: 0f72b296-7b71-4f0f-88ee-ec413fc287f1
2024-05-31 15:47:01 [20:47:01] [Loader Info/1] : Loaded GenericModule version 1.0.0.0 by CubeCoders Limited
2024-05-31 15:47:01 [20:47:01] [Core Info/1] : Metrics publishing is enabled at udp://localhost:12821.
2024-05-31 15:47:01 [20:47:01] [Loader Info/1] : Loaded FileManagerPlugin by CubeCoders Limited
2024-05-31 15:47:01 [20:47:01] [Loader Info/1] : Loaded EmailSenderPlugin by CubeCoders Limited
2024-05-31 15:47:01 [20:47:01] [Loader Info/1] : Loaded WebRequestPlugin by CubeCoders Limited
2024-05-31 15:47:01 [20:47:01] [Loader Info/1] : Loaded LocalFileBackupPlugin by CubeCoders Limited
2024-05-31 15:47:02 [20:47:02] [Loader Info/1] : Loaded CommonCorePlugin by CubeCoders Limited
2024-05-31 15:47:02 [20:47:02] [Loader Info/1] : GenericModule requests dependency steamcmdplugin…
2024-05-31 15:47:02 [20:47:02] [Loader Info/1] : Loaded steamcmdplugin by CubeCoders Limited
2024-05-31 15:47:02 [20:47:02] [Loader Info/1] : GenericModule requests dependency RCONPlugin…
2024-05-31 15:47:02 [20:47:02] [Loader Info/1] : Loaded RCONPlugin by CubeCoders Limited
2024-05-31 15:47:02 [20:47:02] [Core Info/1] : Licence Present: AMP Advanced Edition
2024-05-31 15:47:02 [20:47:02] [FileManager Notice/1] : No SSH keypair available for embedded server, generating new keypair…
2024-05-31 15:47:02 [20:47:02] [FileManager Notice/1] : Generated new keypair with fingerprint CTRd056/hleUaKA56KoY6A4kgZFQNwyxgAV4PObCH1k=
2024-05-31 15:47:02 [20:47:02] [FileManager Notice/1] : Using keypair with fingerprint CTRd056/hleUaKA56KoY6A4kgZFQNwyxgAV4PObCH1k=
2024-05-31 15:47:03 [20:47:02] [FileManager Info/1] : SFTP Server started on 0.0.0.0:2224
2024-05-31 15:47:03 [20:47:03] [Webserver Info/1] : Websockets are enabled.
2024-05-31 15:47:03 [20:47:03] [Webserver Info/1] : Webserver started on http://0.0.0.0:8083
2024-05-31 15:47:03 [20:47:03] [Logger Info/12] : RouterTimer@10Hz with 2 jobs started
2024-05-31 15:47:03 [20:47:03] [Core Info/1] : Checking for AMP updates…
2024-05-31 15:47:03 [20:47:03] [Core Info/1] : Startup mode is UpdateAndStart.
2024-05-31 15:47:04 [20:47:04] [Core Info/15] : AMP is up to date.
2024-05-31 15:47:06 [20:47:06] [Core Error/16] : SocketException
2024-05-31 15:47:06 [20:47:06] [Core Error/16] : [0] (SocketException) : Connection refused
2024-05-31 15:47:06 [20:47:06] [Core Error/16] : at Net.Sockets.Socket.Send (Byte buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
2024-05-31 15:47:06 at Net.Sockets.UdpClient.Send (Byte dgram, Int32 bytes)
2024-05-31 15:47:06 at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
2024-05-31 15:47:16 [20:47:16] [Core Error/14] : SocketException
2024-05-31 15:47:16 [20:47:16] [Core Error/14] : [0] (SocketException) : Connection refused
2024-05-31 15:47:16 [20:47:16] [Core Error/14] : at Net.Sockets.Socket.Send (Byte buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
2024-05-31 15:47:16 at Net.Sockets.UdpClient.Send (Byte dgram, Int32 bytes)
2024-05-31 15:47:16 at ModuleShared.MetricsInfoPublisher.UpdateMetrics ()
- Installed AMP
- Configured AMP to use Docker for new instances per guide on CubeCoders
- Enabled host networking in Docker to check if Docker was not able to communicate to other programs on computer
- Changed metrics port in AMP to 12821 in case something was using port 12820
- Changed default auth server from recommend in Docker setup guide back to localhost to see if this was a possible issue.
