Disable activations?
Hello :slight_smile:
I used AMP on a server that I no longer have—I deleted it, but didn’t delete the instances beforehand.
How can I handle this and transfer the licenses to a new server?
Thank you and best regards!
That’s fine, the licence activations will be removed over time. As long as your current (real) usage is within your limit it’ll sort itself out.
Thank you very much, that really helps!
