More information needed. Did you forward and allow the UDP port? Did you happen to change the port at all in the config? How exactly do you know it’s “blocked” or not working?
yes,no, the mod shows an icon when its unable to pass through the port i also checked using multiple sites to see if the port was open.
I’m aware this might be a problem with Amp’s instance im just clearing all bases
