Customization with Minecraft - Not sure how to add plugins for minecraft server here
I’ve tried to put .jar files (of plugins) in the plugin files, which doesn’t seem to have worked. I’m using WinSCP to try to put .jar files in the Plugin File of the File Manager, and when I start up the server to see if the plugin is present, I can’t find it there. I also don’t want to do anything that could potentially be permanent, since I’m not the one in charge of the server. Could I get an explanation on what I might be doing wrong and how to add plugins properly? Thank you.
  • Open WinSCP
  • Move a .jar file (of a plugin) from my files into server files (Plugin File)
  • Start up server to see if the plugin is present
