Customization with Abiotic Factor - Once updated getting Error (most likely launch options related)
Operating System Linux - Ubuntu 24.04.4 on x86_64
Product AMP ‘Proteus’ v2.8.0.2 (Mainline)
Application Abiotic Factor
I previously had EU4SS working on my server. For UE4SS (Unreal Engine 4 Script System) to work on a dedicated server you have to add the following command as a launch option “WINEDLLOVERRIDES=“version.dll=n,b” %command%”
I forgot where i did this previously and any help would be appreciated.
Thanks
  • Previously had UE4SS working on the instance of Abiotic Factor
  • Updated the instance of Abiotic Factor
  • Most likely defaulted due to update the launch options back to “WINEDLLOVERRIDES=“dwmapi.dll=n,b” %command%”
Added screenshot if it helps of Error. Maybe explains some other issue.
